Rubi Springs on my weak sprung ride
Old Apr 2, 2012 | 05:53 PM
Ol' Bob's Avatar
Default Rubi Springs on my weak sprung ride
I have a 2010 Mountain 2 door. My springs are 55 and 14, there is a forum member with rubi unlimited 59 and 18.
How would that work and how much boost would I get?
Is this a compatible possibility?
Thanks Guys,
Ol Bob
Old Apr 2, 2012 | 06:14 PM
Hotspur's Avatar
I had the same springs on my 10 two door. Got a set of 18/59s and gained about 1.75 inches. Do it, you won't be disappointed. Look for some low mileage Rubi shocks too.
Old Apr 3, 2012 | 04:23 AM
Ol' Bob's Avatar
Can you us the four door springs on a two door?
Old Apr 3, 2012 | 04:28 AM
MikekiM's Avatar
I got the exact same result and the ride was DRAMATICALLY improved. I left one front TF leveling spacer, removed the second and the rear. Roll, yaw, squat and dive were drastically improved. Even more so now that I have the hard top off.
Yes.. Typically the higher rate springs came in the JKU Rubi with the tow package and hard top... so they are a direct fit to your JK.
Old Apr 9, 2012 | 01:08 PM
Ol' Bob's Avatar
Thanks guys. Looking for some shocks also. Maybe Skyjackers or Daystar. They're priced reasonably and should be better than the stock rubi shocks. Any opinions?
Old Apr 9, 2012 | 01:28 PM
Malan35's Avatar
I just did the springs when I did my Teraflex BB. I went off roading this weekend and the ride was STIFFFFFFF. I couldnt stand it. I would HIGHLY recommend getting new shocks. The factory shocks are rated for a certain spring ratio and the stiffer springs wont go well with the factory shocks.
Old Apr 9, 2012 | 01:29 PM
Atch's Avatar
I'd highly recommend the rubi shocks over the skyjackers, typically you get what you pay for!!
Old Apr 9, 2012 | 01:31 PM
Atch's Avatar
If he's using the shocks that came with the springs he's good to go, should be a great ride
