Factory rubicon wheels with 33s?
Old Apr 8, 2012 | 07:44 AM
Chew's Avatar
Default Factory rubicon wheels with 33s?
I have a 2.5 OME lift and no body lift. What will happen if I run 33s on the factory rubi wheels? Rubbing? Or will they fit. Thanks for the info.
Old Apr 8, 2012 | 07:51 AM
rays0852's Avatar
They might rub a little on tight turns and fully flexed....simple solution though. Spidertrax Wheel Spacers.
Old Apr 8, 2012 | 07:59 AM
Chew's Avatar
Thanks for the info. I just really like the factory wheels and don't want to upgrade right now.
Any idea how much backspacing I need for that setup?
Old Apr 8, 2012 | 08:04 AM
aldaman's Avatar
At least 4.75" in back spacing. The factory wheels are 6.25" and if you add wheel spacers with 1.50" that will give you enough clearance to run a ~11-12.5" wide tires...
Old Apr 8, 2012 | 08:20 AM
Chew's Avatar
Thanks!
So with the factory wheels, I should be shopping for 33x?x17 With the ? being up to 12.5?
Old Apr 8, 2012 | 08:40 AM
71Luber's Avatar
33x12. 50x17 or 285/70/17
Old Apr 8, 2012 | 08:51 AM
aldaman's Avatar
Originally Posted by Chew
Thanks!
Correct, just like the sizes 71luber posted....
Old Apr 8, 2012 | 08:57 AM
Chew's Avatar
Thanks guys. I appreciate the info.
