JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Off camber--which way do i streer?
Old Apr 15, 2012 | 05:16 PM
stevedolce's Avatar
Default Off camber--which way do i streer?
Ok--which way do i steer if I'm off camber?? My passenger wheels are up high and I'm traveling downhill..do I turn unto the hill or agai st!?
Old Apr 15, 2012 | 05:17 PM
4WheelingAstronomer's Avatar
Downhill is my answer
Old Apr 15, 2012 | 05:23 PM
FresnoJK's Avatar
Always turn into the potential flop if need be. Turn "driver" in your example.
Old Apr 15, 2012 | 05:24 PM
Robsmst's Avatar
When going up or down hill always try to go as straight as you can. Don't go sideways on a hill.
Was your sway bar/links disconnected?
If an obstacle pushed your passenger front tire up, it should come down as soon as you clear it. Then the rear will hit it.
I'd pick a line where your can stay as straight as possible.
Also don't wheel alone. Hook up with an experienced wheeler and learn from the lines they pick or have the spot for you.
In time you will learn your Jeep. But even then always good to wheel with someone.
To answer your question, turn in the direction that will point you straight up and down on the hill and bring your camber back to normal.
Old Apr 16, 2012 | 09:52 PM
CourtingPanic's Avatar
turn the steering wheel to the left. don't be afraid to straddle voids like ruts if it will keep you level.
Old May 8, 2012 | 07:30 PM
cfr's Avatar
cfr
This is a little confusing due to the wording. Assuming that you're moving forward, turn the front-end downhill if you think you're going over. If you're real worried, step on the gas too. Watch a bunch of rollover videos on youtube until you understand this.
Old May 12, 2012 | 10:47 AM
DeucesALLin's Avatar
Default Forward / rearward motion VS...
...lateral motion. Skids, rolls, drifts... JUST AD THROTTLE!!!
Old May 12, 2012 | 12:43 PM
Tycho's Avatar
I'd also add that if you have to cross sideways across a hill avoid using lockers as in my experience they make you slip down the hill rather than being of any use (plus they'll hamper steering)
Old May 18, 2012 | 05:57 PM
genesbro's Avatar
Kind of like steering into a skid, you steer into the roll and get on the gas to get things lined back up.
Old May 18, 2012 | 06:24 PM
keithvegas's Avatar
If you have a good spotter, turn in the direction he tells you to. As said, you do want to be as straight down hill as the trail allows because you have around 50 degrees of angle before you roll (depending on your rig set up) front and back but closer to 30 side to side. If turning driver or downhill is still an acceptable line then it will help your off camber but if it will get you stuck or dump you hard you could be in a worse situation. If the angle is getting bad and you have enough people, put a strap or rope around a roll bar and have them pull you more level. If they have the balls they can stand on your high side rails to keep you upright.
