Swapping gears
Old Apr 17, 2012 | 05:03 PM
hibypass's Avatar
Default Swapping gears
I was told by a reputable mechanic that swapping out gears with used ones is a bad deal. He said they will never "run in" correctly again. Does anyone have any experience with this? I want to swap my stock 3:21's for 3:73's. Thanks for the input in advance!
Old Apr 17, 2012 | 05:14 PM
JGP4JK's Avatar
I've heard the same thing just this weekend actually. New gears are cheap enough to buy new, especially if you buy the front/rear package. Northridge 4x4 has the complete Yukon front/rear set with install kit for $445.
Old Apr 17, 2012 | 05:15 PM
shaggy591a's Avatar
Veteran: Navy
I have swapped in used 4.10 gears. They had around 20,000 miles on them. No problems with them at all. I put around 10,000 more miles on the so far. I had 3.21 gears so I had to change them when I got the 35s on.
Old Apr 17, 2012 | 05:21 PM
hibypass's Avatar
Thanks for that idea. I think I'll check Northridge out!
Old Apr 26, 2012 | 04:56 PM
redunlimitedguy's Avatar
Default have 3.21s
Was wandering what your rpms are shaggy after swapping in the 4.10s. Was thinking I might go 4.56 if possible
