superchips axle lock help.......
Old Apr 19, 2012 | 08:13 AM
RELENTLESS's Avatar
Default superchips axle lock help.......
k so will someone please explain to me how this works and how you do it with the tuner ? I understand you have to leave the tuner plugged in while you use this feature? true ? also does it work on any model? rubi? sport? x? cause I have the base model x and am not even sure if I can use this feature? thanks for any info
Old Apr 19, 2012 | 08:21 AM
Inko's Avatar
No you cannot use this feature. You do not physically have lockers in your jeep, only the Rubis had lockers and as far as I know you could only lock them while in 4 low. The superchips from what I understand allows you to lock them while in 4 hi....
Old Apr 19, 2012 | 08:47 AM
Saharaunlmtd's Avatar
Did that really just happen?
Old Apr 19, 2012 | 08:57 AM
RELENTLESS's Avatar
alrighty thank you !
