What should I expect after installing longer swaybar links?
I am finally installing longer swaybar links this weekend. I installed a 2.5" BB a few months ago that did not come with the longer bars. Am I going to notice any difference while driving?
Thanks
Then why is it so important to add longer links in the back and move the original back ones to the front for a lift as small as 2.5"? It's important enough that they are now part of BB kits like the TF kit and others?
Adding longer links keep your swaybar links from being the limiting factor in your suspension droop/articulation. If you're not running disconnects in the front, keeping the stock links with a lift can limit your downtravel. Also, if you happen to have a rubi with the e-disco, you run the risk of drooping past the capable length of your links and flipping the swaybar the opposite direction.
-Adam
-Adam
