Can I run 35 spline front axle shafts and axle sleeves?
Old Apr 19, 2012 | 05:06 PM
19Delta's Avatar
Default Can I run 35 spline front axle shafts and axle sleeves?
I am looking at getting an ected max, which requires 35 spline shafts. I thought I had read somewhere awhile back that I could not because I have already welded in my sleeves.
Anybody have any experience?
I have an 07 rubi unlimited.
Thanks!
Old Apr 19, 2012 | 05:47 PM
19Delta's Avatar
OR, does anyone have any info if I can get a regular ected (not max) and run stock shafts. For the wheeling I do, that would be fine I think, I do run 37's, but live in indiana. Not a lot of rocks.
Old Apr 19, 2012 | 05:51 PM
knnphillips's Avatar
I believe 35 spline shafts can't be used since your running sleeves but you can get chromoly shafts the same spline count as stock shafts. If you put in a regular ECTED and break a stock shaft.
What happened to your stock locker?
Old Apr 19, 2012 | 05:58 PM
19Delta's Avatar
Dunno. Just won't work. Electric to it is on, and it even "clicks" (electrically) when engaged. But wont lock.
Back works great.
Old Apr 19, 2012 | 06:12 PM
D_engel's Avatar
i think the nitro sleeves are the only ones that allow a 35 spline
Old Apr 19, 2012 | 06:16 PM
If this is true I believe it's the sleeves I'll go with.
