Need better tires
Old Apr 22, 2012 | 01:54 PM
Mr Jeepster's Avatar
Default Need better tires
I need some meatier tires for my stock 2012 JKU. Have 17" rims. Do I need to level the rake first? Can someone recommend a beefier tire for the Stock set-up of a 2012 Sport S?
Old Apr 22, 2012 | 02:08 PM
awinski's Avatar
you should be able to run up to a 33 on a stock setup, it may rub a little. or you could always just go with a 32. also depending on how much you wheel a set of 1-1.5" wheel spacers so you don't have to worry about rubbing. as for brand of tire that all matters on personal opinion and price range
Old Apr 22, 2012 | 03:35 PM
Jeepnut67's Avatar
Post Duratracs!
I run 265/75-16 on my stock steelies & love 'em. Huge improvement over the stock STs
Old Apr 26, 2012 | 01:32 AM
joncolecollett's Avatar
ok whaever size you chose I would go with nitto terra grapplers
Old Apr 26, 2012 | 05:22 AM
Kalamari's Avatar
You'll get all kinds of recommendations on this one. I like the Hankook Dynapro MT's. They're stock size on my 2.5" lifted Jeep. I'll get bigger ones next time.
Name:	Screen shot 2012-01-22 at 12.42.42 PM.jpg
ID:	309395   Click image for larger version
Name:	Screen shot 2012-01-22 at 12.40.33 PM.jpg
ID:	309397   Click image for larger version
Old Apr 26, 2012 | 05:24 AM
Topkicker1's Avatar
I ran 33x12.5 Pro Comp A/T's on 17x9's w 4.5 BS on stock suspension. It would rub a little when flexed but not that bad and not very often. Here's an old pic.
Old Apr 26, 2012 | 05:34 AM
bwayers's Avatar
If you're up for going to 15s, you can get wheels and tires for almost the same as tires for 17s
I'm just biased though I love big sidewall
Old May 14, 2012 | 08:11 AM
I ended up installing a Teraflex leveling kit and went with 285 70 17 ( 33") Nitto Trail Grapplers.
ID:	316816   Click image for larger version
