Rear Drive Shaft Replacement
I plan to replace my rear drive shaft. No problems with it yet and want to keep it that way. I have a TF 3" lift on a 2011 2-door. I presently have spring wedges to take the bow out.
After installing an aftermarket CV style shaft and setting pinion angle, will the wedges be enough or will I need to relocate the perches?
Any problems with the rear sway bar links hitting the shock brackets or trackbar brackets?
Thank you!
Thank you!
I just replaced my fr/rr with Tom Woods 1310's, although the shafts work well I think it is a poor design, first of all, you have to replace the diff yoke with the Tom Wood custom once (fr/rr). Tom Wood did away with the seal protection of the yokes to the diff, bad idea. I am wheeling a lot in sand and swamp and both front, mid and rr seals are all damaged. OK not leaking (as yet) but TW just took away the dust/mud/dirt cover, claiming that their tolerances are far better. Tolerances my bum.....I need mud/grass protection....:crazy eyes:
Also if you wheel a lot in sand and water/grass the open CV design is not very good, every time I have to clean and regrease the CV joints, thinking about putting some kind of sleeve around the CV joints......again did TW really think through the design......
My two cents
My two cents
