New to Jeeps and need wheel size help!
My wife just got a 2012 Jeep Wrangler Unlimited Sahara. The cherry red color.
She is wanting one of the following black wheels... XD Rockstars, XD Addicts, or XD hoss. In order to not have to buy new tires now we are going to with an 18" wheel. The stock tires are 255/70/18 will these fit right on a 9" rim? Also what would be the correct offset to get? I see different offsets on each wheel.
BP 5x5
offset????
I am leaning more towards the addicts or the hoss because the Rockstars are kind of played out. I like that the Hoss come in gloss black.
If you have any pictures of any of these wheels on a stockish jeep ( especially a cherry red unlimited) please post.
Thanks.
BP 5x5
offset????
Thanks.
I looked at the back of my stock Moabs and it showed Offset of 44.45mm. Then considered backspacing of 6.25"...Now I am looking at a wheel with 4.5" of back spacing and -12mm of offset. I believe this would put the wheel a bit further out in the well?
just a bit and, if you're running wider tires like a 12.50, this is needed in order to prevent any rubbing of the rear sway bar links or at a full turn.
