How to tighten the steering wheel
Old 05-02-2012, 11:29 AM
09jaykay's Avatar
Default How to tighten the steering wheel
I have a lot of up and down play in the wheel, so im wondering if anyone has a write up on how to take it a part to re torque everything down. thanks
Old 05-02-2012, 11:35 AM
JK-Forum Founder
wayoflife's Avatar
a lot of play while driving at highway speeds or, a lot of play in general as in, while at a stand still, you can turn the wheel quite a bit left and right without actually turning the wheels?
Old 05-02-2012, 11:50 AM
09jaykay's Avatar
Play as in sitting still i can pull the wheel up and down or left to right. the actual turning of the wheel while driving and siting still is fine.
Old 05-03-2012, 09:37 AM
cajunaviator's Avatar
Is just the steering wheel moving or does the entire steering column move? Do you have the height adjustment lever in the locked position. It is on the left side of the column to raise and lower the height of the steering wheel.
Old 05-03-2012, 01:57 PM
09jaykay's Avatar
Its just the wheel, i know a saw a write-up on how to change the clock spring that should how to take the wheel off but now i can't find it
Old 05-03-2012, 02:06 PM
fivenote's Avatar
Search for the write up on installing cruise control. Still, what you describe sounds strange. After you pull the center cap and airbag (disconnect battery first!) there's just one center bolt holding the wheel on. Even when that is removed the sucker is on tight and won't budge without a fight. That's why the instructions come with a warning not to hit yourself in the face when the wheel finally pops loose.
Old 05-04-2012, 06:16 PM
09jaykay's Avatar
It is strange and it's get worse
Old 05-11-2012, 09:49 PM
09jaykay's Avatar
In case anyone else has this problem, i was able to fix it by tightening the main bolt under the airbag. Its as good as new now.
Quick Reply: How to tighten the steering wheel
