Hard top hoist
Old May 6, 2012 | 04:08 PM
JDanderson's Avatar
Default Hard top hoist
Hard top hoist done and only cost $50 an one person can take it off
ID:	313681   Click image for larger version
Old May 6, 2012 | 05:22 PM
chrisd0729's Avatar
Any pics of the hard top hook up? How did you connect to the top?
I was thinking of doing something similar but, a separate rope for each corner. I was thinking 4 separate ropes, going through 4 separate eyelets on the ceiling. and then a strap underneath each side of the hard top... I'm curious to see how you attached the top...
Old May 6, 2012 | 06:17 PM
JDanderson's Avatar
Hard to put the top back on gonna rain
All I did is use two ropes wrapped them around the top while on jeep. If you look on your top in the front right above the speaker console there are two notches I uses for a guide for the ropes then with the glass down I used the glass brackets for a guide with the one in the front. I worked well and pulled evenly just make sure your ropes are tied evenly on the top then hoist away. I'll try to get pics later this week
JDanderson's Avatar
Had to put top on not hard
