Atx slab with beadlock vs. normal 17" aluminum rim?
beadlocks help keep the tire mounted to the wheel when you air down for offroading. very much advantageous.
and the weight difference completely depends on what 17'' aluminum rim you are talking about.
you will probably bend your Cs before you bend your axle. if you go anything over factory sized tires it seems the general and popular idea is to gusset your Cs. what size tires are you running / looking at? overall weight between tires and wheels is what you need to be concerned with.
if you are on 37s i cant imagine that a few more pounds on the wheels are gonna make that much difference. you will def pick up some weight, but there wont be a soul on here that can definitively say you will or wont mess up your drive shaft by getting beadlocks.
