RK 2.5 max flex
Old May 8, 2012 | 01:26 PM
Cherryjk's Avatar
Default RK 2.5 max flex
Plenty of flex with this kit. Disconnecting the swaybar links is must.
ID:	314378   Click image for larger version
Old May 8, 2012 | 02:13 PM
Dayman's Avatar
Ouch! Man that is a lot of flex, I'm looking at the rk 2.5 flex. How long are your shocks? Did you have any bump stops?
Old May 8, 2012 | 02:19 PM
Cherryjk's Avatar
The shocks are 27.5 fully extended. I will get bump stops when I get bigger tires no need for them yet. The ride is great and the quality of the parts are top notch.
Old May 8, 2012 | 02:34 PM
kgw350's Avatar
The 2.5" RK is kick ass
Old May 8, 2012 | 03:09 PM
EzK's Avatar
EzK
Pic 2 looks familiar!
Old May 8, 2012 | 03:42 PM
Cherryjk's Avatar
What did you do to prevent this
Old May 8, 2012 | 04:21 PM
EzK's Avatar
EzK
Nothing yet, just going to fully disconnect for now. I was considering limiting straps.
(btw, fully disconnected the front passenger spring came out while flexed but I think it had to do with the coil hitting the upper bump stop because the axle wasn't centered enough)
