Sloppy track bar holes. Now what?
After removing my front bolts to install the grade 9 shoulder bolts. I found my holes on the flagger nut side are noticeably larger than my new bolts.
I have never had death wobble but i have a definate wobble/shimmy when hitting pavement seams/joints. I assume this could be my cause. Are you guys welding the grade 8 washer to fix this? What about the back side where the flagg nut is, how can you weld a washer back there?
The other side had minimal wear. Also the threads wore into my trac bar. Does the threaded grooves in the track bar require a new bar?
Attachment 315569
Attachment 315569
you got the washer route
replacing the entire bracket route
redril the bracket and trackbar et go with a biger bolt route
I got the same issue, better verify the stering dampener bracket also, it got the same problem for me.
will do the washer part I think
