One last question...
Old May 12, 2012 | 02:11 PM
BossHog's Avatar
Default One last question...
Hey guys,
My 35" toyo mts mounted with 18" xd monsters are due to arrive Monday. My 2.5" TF coil lift kit is here and ready to go. The off road evolution gussets and my pro cal tuner is slated I be here Wednesday. My goal is to have all installed on Thursday.
My question is, I do not need to run any wheels spacers with this setup, correct?
That's the only piece im missing and I'm pretty sure they are not needed given I'm not keeping my stock wheels. But truthfully, this process has wore me out.
Just double checking. Thanks!
Old May 12, 2012 | 02:21 PM
grumpy1's Avatar
depending on the back spacing on the new rims is what would determin if you need to have wheel spacers. If the back spacing on the new rims is around 4.5 inches then you should be fine. if its more than 5 inches of back spacing then you would need wheel spacers
Old May 12, 2012 | 02:29 PM
BossHog's Avatar
I believe it's 4.53
Old May 12, 2012 | 06:04 PM
BossHog's Avatar
Yea, just confirmed on my invoice. 4.53, so am I good to go with what I have?
No spacers needed?
Old May 12, 2012 | 06:21 PM
jkfanatic's Avatar
sounds like your good to go! post pics when its done!
Old May 12, 2012 | 06:22 PM
BossHog's Avatar
No worries, definitely will!!!
Old May 12, 2012 | 06:55 PM
scooby snacks's Avatar
I am runninig the same exact setup. You won't need spacers... but you will need to trim your air dam.
