Minimum length rear UCA's
Old May 12, 2012 | 03:56 PM
vulcan classic's Avatar
Default Minimum length of Rock Krawler adjustable rear UCA's?
Need a set of adjustable rear UCA's to set my rear pinion. After disconnecting my stockers and playing with pinion I figured I need about 1/4"-3/8" more than stock or about 17 3/4" max, This set my rear CV / RPezza at a nice happy position at the pinion but I will likely need spring wedges to correct bowing and keep track bar jam nut from hitting passenger side spring.
Which brand of arms can meet this length at minimum adjustment? I like RK but not sure they will work with my stock rear lowers?
Old May 12, 2012 | 04:03 PM
NateG12's Avatar
I installed RK adjustable uppers a few weeks ago. I have a 3 inch lift and the RK arms barely had enough adjustment to set the pinion angle correctly. I actually had to shorten them as far as they will go to get it right. Anyhow, they did work and now my pinion angle is good.
Old May 12, 2012 | 04:15 PM
Did you happene to measure them eye to eye at minimum adjustment?
Old May 12, 2012 | 04:17 PM
Also, did you need spring correction or have track bar interference?
Old May 13, 2012 | 06:58 AM
Bump
Does anyone know the minimum length of Rock Krawler rear adjustable upper control arms?
