EVO Enforcer
Old May 14, 2012 | 04:01 AM
RedRockIt's Avatar
Default EVO Enforcer
Hello. I just ordered an Evo enforcer lift. I am "upgrading" from a Full Traction 3" economy lift.
What experiences have you guys had with this particular lift? Did you take it to an alignment shop after installation to set the caster?
Lastly, what shocks are you running? Any reviews running with King, Bilstein or Rancho?
Thanks in advance!
Old May 14, 2012 | 08:00 AM
MTG's Avatar
MTG
I installed this kit in February and absolutely love it. I took it to Moab and it performed great! Tons of flex and rides like a dream on the road. Not sure if you have specific questions or not, but feel free to PM me if you want.
A few things:
1) It drove perfectly after install. I did take it to the alignment shop just to be sure, but I don't think he did much.
2) If you didn't already, get the draglink flip kit as well
3) I'd run extended brakelines over the extensions
4) Turn your rear passenger side trackbar bolt backwards (so the head is towards the front of the vehicle)
5) Watch your rear hard brake lines and the swaybar end link bolts. They came pretty close on mine so I moved the hardlines up. You could also cut the bolts a bit after install.
6) I went with King 2.5 shocks. I considered the Bilstein 5100s before I went "all in" as I heard those will pair nicely with this lift.
7) I don't think you have a 2012, but if you do make sure to move your evap skid over if you are running a stock rear DS.
Best of luck!
Here is a shot from Moab.
Old May 14, 2012 | 08:12 AM
chris@offroadevolution's Avatar
Sponsoring Vendor
Thanks MTG!
We suggest having the alignment check after the install.
please let me know if you have any questions!
Old May 16, 2012 | 06:01 AM
RedRockIt's Avatar
A few things:
Best of luck!
Thanks a lot. That was exactly the info I was looking for. I do have a 2012. I have read a thread about moving over the evap. I didn't move it w my 3" FT lift.
Looking forward to hiring some trails. It is also just a holdover until I upgrade to some coilovers
Old May 16, 2012 | 06:03 AM
RedRockIt's Avatar
Originally Posted by chris@offroadevolution
Thanks MTG!
Thanks. Chris. I can't say enough good things about Evo! If I didn't live so far away I'd def turn in an application
Old May 16, 2012 | 06:09 AM
ddhowel's Avatar
A few things:
Best of luck!
I'd love to see some pics of this lift with 35" tires and stock flares.
It is definately on my short list when I upgrade, I can only seem to find pics of this lift with 37" tires which I won't be running.
Old May 16, 2012 | 06:15 AM
RedRockIt's Avatar
I should be receiving my kit this week. At this time I'm running 35s with stock fenders. Will try to upload some shots when the build is complete.
Old May 16, 2012 | 06:52 AM
ddhowel's Avatar
Thanks, I'll be looking forward to the pics
Old May 16, 2012 | 07:29 AM
MTG's Avatar
MTG
No problem. The skid takes about 10 minutes. You'll love it. The coilovers look nice. I was fortunate to drive behind rubicat in moab and was super envious. Let me know if you have any other questions.
Old May 16, 2012 | 07:35 AM
MTG's Avatar
MTG
The pic I posted above is on 35" duratracs (315/70/17 actually) and stock fenders. I'm happy to post up or email more. Let me know.
It's a great lift! You'll be hard pressed to beat EVO quality and service. One nice thing is you can run 35s and then upgrade to 37s by either running flat flares or changing the bump stops.
