How to check ball joints, axelc c's, and sleeves?
Old May 14, 2012 | 07:13 AM
Maertz's Avatar
Default How to check ball joints, axelc c's, and sleeves?
I want to check over my front end but am unsure what to look for. It looks like to check the ball joints and bearings i need to jack up the axle and lift on the wheel to see if there is play. How can i tell if the axle is bent? Put a level on it on level ground? Also what should i look for when inspecting the sleeves? My camber is -.7 on each side, just want to see, even though most people are saying its fine. Also my toe in and out seems to be constantly getting messed up is there a reason for this? I have just taken it in for an alignment and they claimed they were having issues getting it to hold but that they got it now. I looked at the front end 2 days later and it looks like the front left tire is pointing out ever so slightly? Lots of questions, but i don't know much about this stuff. I have the stock rubi tires but want to get 35s so i figure i should address all of this first.
Thanks for all the help in advance.
Maertz
Old May 14, 2012 | 06:37 PM
Maertz's Avatar
On the axle sleeves are those the plastic circles that go into the axel housing?
Old May 14, 2012 | 06:46 PM
Biggy's Avatar
That plastic cap is just a dust cover to keep crap out of the axle tube . A axle sleeve is a tube that is placed inside the axle tube to give it more strength. Search evo sleeve or nitro sleeve and you will see what I'm talking about.
