Cracked front rubicon dana 44 that has been sleeved and gusseted
Old May 15, 2012 | 08:40 PM
ryant's Avatar
Default Cracked front rubicon dana 44 that has been sleeved and gusseted
My axle houseing has about a 2 1/2 in. Crack where the plug welds were from the axle sleeves. Can this be welded back up? What are my options, thanks
Old May 15, 2012 | 09:04 PM
suicideking's Avatar
I don't know how to fix it, just curious if you know how you cracked it?
txjeeplover's Avatar
First, sorry that happened! Second, is the housing cracked or is the tube cracked? A tube can be replaced but if the housing is cracked, you should scrap it and start fresh. If you weld a cracked housing, it may prevent a leak for a while, but eventually the stress on the area will cause catastrophic damage. With the replacement options available from Dynatrac and Teraflex, it's probably cheaper to buy a new axle.
Could you please post a pic of the damage and your axle setup? I ask because my current plan is to have my Rubi's front 44 sleeved and gusseted at the C's, but your event coupled with other incidents I read about on the Forum have me reconsidering. I may just do gears now and save up for a proper axle from Dynatrac or Teraflex.
Old May 15, 2012 | 09:13 PM
ryant's Avatar
I think it was kind of a freak thing and can't narrow it down to just one thing other than a few years of wheelin. I will post picks tomoro
Old May 16, 2012 | 05:19 AM
FireMedic1343's Avatar
Did you do the weld yourself? Someone may have welded too fast, too much heat maybe...
Old May 16, 2012 | 05:42 AM
ryant's Avatar
No a professional shop did all the work
Old May 16, 2012 | 05:52 AM
rb1boxer_3's Avatar
All I can say is if it's just a crack coming from the weld drill a hole at the end of the crack to stop it from going more then just weld it.
Old May 16, 2012 | 12:55 PM
ryant's Avatar
Here's a picture
Old May 16, 2012 | 01:48 PM
jokerforever's Avatar
From: Minot, North Dakota--not by choice--I belong in Dixie
+1
What are your Jeep's specs; big tires, a lot of weigth on the front? Were you wheeling at the time?
Old May 16, 2012 | 01:56 PM
LMT Rubi's Avatar
Wow! this is a very interesting thread to say the least and I am sorry this happend to your JK OP.
