Exhaust Upgrade
Old May 16, 2012 | 07:29 AM
BlackXUnlimited's Avatar
Default Exhaust Upgrade
On the market for exhaust. My JK is completely stock exhaust wise. Suggestions? I don't wanna go too loud .
Old May 16, 2012 | 08:11 AM
Mr.ZAP's Avatar
What year?
Old May 16, 2012 | 08:16 AM
Originally Posted by Mr.ZAP
What year?
08 wrangler unlimited x
Old May 16, 2012 | 08:20 AM
Mr.ZAP's Avatar
I know you said not too loud, but I have mine chopped off and I like it pretty well. The farther back you cut, the 'quieter' it gets. Mine is cut below the driver's seat, but I bet if you did it behind the rear axle it wouldn't be too bad. Relatively free and easy mod. Makes highway driving a little better, too. Otherwise, I would say throw a Flowmaster on it or the like.
Old May 16, 2012 | 08:25 AM
holmes4x4's Avatar
MBRP is the way to go just dont buy the black version the coating will peel off paint it yourself with 2500 degree paint.
Old May 16, 2012 | 08:34 AM
holmes4x4's Avatar
Here is the link for my MBRP sound clip. http://www.youtube.com/watch?v=9Z5ZR...ecAUAAAAAAAAAA
Old May 16, 2012 | 09:19 AM
Dynomax's Avatar
Sponsoring Manufacturer
Look to a system that keeps the muffler in the stock location, this will keep it the "quietest"
Originally Posted by mpkelley20
I'm about to modify my Dynomax Rock Crawler exhaust because my new lift is causing rubbing on the rear track bar and sway bar. I was planning on removing the entire rear pipe that extends from the muffler (which sits under the middle of the Jeep) and throw on a turn down pipe. Will this make it quieter? I was assuming it would get louder.
A bit louder but nothing too bad. I sent you the P/N right?
Old May 16, 2012 | 10:46 AM
Dynomax's Avatar
yes you did thanks! You also said to check the local auto stores which I did and I can get a very cheap turn down tip if I don't want stainless. I was going to pick one up (they are around $8 or so) just to give it a try. Not sure on size yet but I think it would be 2 1/2" that I would need, right?
YUUPPPP! Also reuse the same clamp.
And got your PM too.
Old May 16, 2012 | 11:09 AM
TJM12's Avatar
I've been enjoying the corsa db, sounds good, not loud, has a cool gurgle. Tucks up higher than stock and is lighter too. Some drone in the cabin at lower speeds but not do much at highway speeds.
Old May 16, 2012 | 08:59 PM
Mr.ZAP's Avatar
Try to find 2.5" O.D., it will slide (kinda) right over the existing pipe and then you can clamp it there. Also, this will make it quieter in the cab, but louder for everyone else.
