34" tires, If's, And's, But's
Old May 17, 2012 | 09:49 AM
Muneblade's Avatar
Default 34" tires, If's, And's, But's
I have been told not to put 35" tires on my new 2012 JK. The argument is that I wheel too aggressively (lead foot), and my dana 30's will not take the added weight/abuse. I am not keen on 33's want something a little bit bigger. My new thinking is to possibly bridge the gap and go with 34's. I plan on putting on a 2.5" coil lift, but run my stock (Sahara) fenders. I understand that I may rub at a full flex, but I don't plan on flexing my jeep that much. My jeep is my daily driver. What are the pro's and con's to running 34's?
Old May 17, 2012 | 10:00 AM
finfreeze's Avatar
If you have 35's you won't have to wheel as hard. Problem solved!
I know I love mine and can't wait until they wear out so I can join the 37 club.
Old May 17, 2012 | 10:28 AM
JE8154's Avatar
Originally Posted by Canuckjkjeeper
Most 35's are more like the size of 34's anyways....my brand new Toyo M/T's measure exactly 34.25" at 40psi
You aren't running them at 40 psi are you?
Old May 17, 2012 | 10:33 AM
Muneblade's Avatar
So I shouldn't worry about breaking my front Dana 30 due to a 35" tire?
Old May 17, 2012 | 10:40 AM
Muneblade's Avatar
vs. a 33" tire...
Old May 17, 2012 | 10:42 AM
finfreeze's Avatar
"C" gussets are a good idea but unless your hauling ass (its a jk, come on....) On a section of whoops or jumping and slamming the front end alot, you will be fine.
Old May 17, 2012 | 11:26 AM
4W-Jive's Avatar
gussets and cro mo axle shafts prob wouldn't be a bad idea
Old May 17, 2012 | 12:14 PM
BlackXUnlimited's Avatar
vs. a 33" tire...
Don't do 33's. Been there done that. Huge regret.
Old May 17, 2012 | 12:22 PM
FoxRacingJMC's Avatar
Saying goes.... If you are thinking 35's, get them cause if you get 33's, you will regret it. Don't wheel like a re-re, take it easy on the skinny, take the proper lines, and you will be happy with 35's.
You're only talking 1"-1 1/2" average difference really... so, get roped up and make up your mind...
Also keep in mind, the more "odd" sized tire you get, the harder it is to find a spare in a pinch..... 33's & 35's are common, 34's - not as much
Old May 17, 2012 | 01:31 PM
Rule18's Avatar
x2... Make the jump now!
