Another "going to 35's" Thead ?!?!?!?!
Old May 17, 2012 | 04:59 PM
EK's JK's Avatar
Default Another "going to 35's" Thead ?!?!?!?!
Humor me. Tomorrow I am ordering the following: Teraflex 2.5 coil lift with bilstein 5100's, Teraflex adjustable track bar (and the new bolt kit), exhaust spacer kit, Bushwacker flat flares, 35" BFG KM2's on black AEV Pintlers. Probably gonna get some ACE rock rails too. Anything I am missing? Pics of a similar setup would be helpful. Thanks.
Old May 17, 2012 | 05:13 PM
keithvegas's Avatar
Doing the lift yourself? If so do you have all the tools? Torque wrench, jack stands, locktite
Old May 17, 2012 | 05:16 PM
JE8154's Avatar
At first people said to go with the exhaust spacers but apparently this is just a bandaid and you're drive shaft is going to cause problems eventually anyways. So I went with a Coast 1310 and left the spacers out. The spacers actually drop your exhaust cross over to the point where it is even or below the cross member so it isn't a good idea anyways if you plan on going off pavement.
HALCYONTSF's Avatar
All my crap is in the garage waiting to go on the jeep next week when it arrives but you're forgetting bumpers and skid plates.
BTW I have a set of spacers I'll sell you for cheap. I bought them then decided to go with a new drive shaft instead.
ID:	318183   Click image for larger version
ID:	318184   Click image for larger version
afpilot82's Avatar
JK-Forum Ambassador
Might want to pick up an AEV Procal to reset your speedo. Also, there are a couple threads in the Show & Tell section concerning 2.5" lifts.
Old May 17, 2012 | 05:19 PM
HALCYONTSF's Avatar
Can the dealer recalibrate the speedometer?
Old May 17, 2012 | 05:21 PM
aldaman's Avatar
Only up to 32" tires, which is the biggest tire available (from factory) for stock JKs...
JE8154's Avatar
only up to a 32
Old May 17, 2012 | 05:25 PM
EK's JK's Avatar
I have the bumpers and winch already. I plan on doing the lift myself in my modestly equipped garage. David at Northridge recommended the exhaust spacers, so I thought "What the hell!" I don't do a lot of extreme offloading, just trails for camping. It is a 2012, so no Procal :( I thought about driveshafts but it is too much $$$ right now. The wife was good enough to go along with all of this so I don't want to push my luck. So realistically, how long before the driveshafts crap out? It is only a 2.5" lift..
Old May 17, 2012 | 05:33 PM
TJM12's Avatar
Wow you must have spent a heap of cash? That is alot of goodies you got there.
