36x13.50x17 will they fit
Old May 19, 2012 | 07:22 AM
shanesup's Avatar
Default 36x13.50x17 will they fit
I have a 2011 rubicon unlimited with a teraflex 2.5 coil lift and 1" spacer in front and 1/2 spacer in the rear I would like to run the irok 36x13.50x17 tires i have aev pintler wheels. Will they fit
Old May 19, 2012 | 10:52 AM
shanesup's Avatar
With stock rubi tires
Old May 19, 2012 | 11:45 AM
Ryan0260's Avatar
You will need wheel spacers and some trimming and they will fit
Old May 19, 2012 | 11:56 AM
Delux2769's Avatar
If your wheels have enough backspacing, you won't need wheel spacers. Although they would be a good idea to give that extra width since your tires are 13.50" wide and most pees only run 12.50".
You should trim your pinch seam as well.
Otherwise you should be set.
Flat fenders would be good idea for looks and stuff more.
Old May 19, 2012 | 12:36 PM
shanesup's Avatar
I have the ave pintler do you think the offset will work with out spacers
Old May 19, 2012 | 02:44 PM
kenjiyukawa's Avatar
Default 35s
If you want 35s consider a 4" suspension lift. It will cost you a little extra $ but will have a better stance with no rubbing/trimming/spacers needed...
It will also allow you to go to 37s or 40s with a body lift! (i know i prob will want to one day...)
Pro Comp 4" Suspension Lift
35 x 12.5 Pro Comp Extreme All Terrain
Smittybilt XRC front bumper
Smittybilt XRC Rear Bumper
Smittybilt XRC Tire rack
ID:	318837   Click image for larger version
ID:	318838   Click image for larger version
ID:	318839   Click image for larger version
Old May 20, 2012 | 04:27 AM
shanesup's Avatar
I have see plenty of people with a 2.5 lift with 35s. I have 3" in the rear and 3.5 in the front I know I will need to cut the pinch seam just need to know will they fit without spacers.
Old May 20, 2012 | 04:59 AM
Mudbob's Avatar
im running 35s with 2 inch mopar lift. its tight but with your lift 36s should be fine
Old May 20, 2012 | 11:55 AM
Dr. Satan's Avatar
I would think your biggest obsticle would be the backspacing. The pintlers are 4.7" which is good for 12.50" wide tires but you want 13.50". You may need wheel spacers to make it happen. If you are willing to run spacers then; buy your tires, if they won't fit, buy some spacers. If you aren't willing to run spacers stick with 12.50" tires.
Old May 21, 2012 | 02:55 PM
shanesup's Avatar
Thanks for all the help
