Nitto 35 tire question
Old May 20, 2012 | 08:19 PM
hoghd06's Avatar
Default Nitto 35 tire question
Just wondering if I put 35" trail grapplers could I just use a 2.5" budget lift and not have to do other mods to make it work? Eventually I want the rk max travel 2.5 but I am not sure what will work. I plan I doing mid level off roading
Old May 20, 2012 | 08:27 PM
Fyrefighter's Avatar
35" nitto trail grapplers with 2.5" pro comp lift. So I'm sure you would be fine
Old May 21, 2012 | 04:28 AM
Ryan0260's Avatar
It will work fine, but you might want to cut or use flat fenders to avoid rubbing during extreme flex
Old May 21, 2012 | 01:13 PM
eumel789's Avatar
You always can add wheel spacers if need be.
