Need help quick! Manual Transmission will not shift
I was on my way to go hit up some trails and just shifted out of first gear when pulling away from a stop sign and I was not able to shift into any gears after that. Has anyone ever heard of this before? Will whatever the problem be covered under warranty? I have a 2011 rubicon with just over 10k. I tried switching the transfer case into 4low and 4high and was not able to shift into any gear or reverse.
Originally Posted by Surf City Dan
This happened to my Rubicon a month ago. Clutch disc was actually tweaked/bent. Had the clutch, pressure plate and throw out bearing replaced now its good as new.
