Tell me about Hanson Offroad Rock Sliders...Install and Quality!?!?
Buying some rock sliders in the next week or so.
Pretty sure I will be going with EVO Rock Sliders but, for the longest time I was looking at the Hanson Rock Sliders.
If you have them installed, show them, and tell me everything you have to say about them...Install, quality, finish, how much abuse have you put them through, how they are holding up, etc.
If you planning on playing hard in the rocks, I would go with the EVO sliders. These sliders are welded to the frame and will hold up to anything you can throw at them. This will open up the Frame mount vs body mount debate...
Originally Posted by chris@offroadevolution
The Hanson rockers are a really nice piece. They are mounted with Nutserts into the tub and mount along the pinch seam. They will take some hits.
If I remember correctly, there are 11 bolts (on each side) along the lower pinch seam holding the slider to the body. The slider is quite heavy and strong. The 4 nutserts (on each side) are mostly to keep the slider from bending outward. I have slid on rocks and reguarly use the step without any problems to the body. Being attached to the body gives the jeep a little extra ground clearance.
Since I live in Texas, I don't have to worry as much about corrosion from snow and ice removal like our northern friends.
