LOD Door Linked Tire Carrier Question
There is a tire size limitation (weight) due to the factory tail gate latch. I'm getting ready to order a shorty version of the door linked setup but I have concerns that there will still be gate wear. Not the hinges but the latch. I'm wondering if the non-linked carrier may be the way to go. I know the door linked carrier has not been available for too long but are there any.pro's or con's anyone can chime in with about the door linked carrier?
I went with the shorty NON linked for the simple reason that I really wanted the trail rack. The linked version will no support the trail rack, and they will only let you run a single gas can mount, all due to weight restrictions and the factory latch. I am really happy about my decision...their trail rack is awesome!
I know the weight is off the gate up and down but apparently the front to back movement or vibration could take a toll on the latch. I checked Northridge, David doesn't seem to carry the shorty with a latch or non- attached. At least it's not list I his site. Maybe I should call. Still not set on which way to go.
Doesn't somebody out there make a linked carrier that also has a latch pin to the bumper?
I think I saw where Rampage's new design does that? If it works, (and doesn't rattle too much) wouldn't that be the best of both worlds?
Does anyone have such a contraption?
UPDATE! (light bulb): Even better, have a handle to select between ink to tailgate and latch to bumper!!!
I emailed David at Northridge, he said he could get either version I wanted.. I asked if he knew of any issues with the linked version, he replied none that he knew of. Now I just need to make up my mind on a linked or non linked..
