What have you broken on your JK?
Old May 21, 2012 | 04:52 PM
TURTLECON's Avatar
Default What have you broken on your JK?
Like the title says... I'm curious what have you broken on your JK? What caused the damage and how did you fix it? Replace with a new part or did you use creativity to repair the problem MacGuyver style?
Maybe we can all learn a few new tricks!
Old May 21, 2012 | 04:54 PM
dlincoln91's Avatar
Ring and pinion-dana 30- replaced with a 79 ford kingpin 60
multiple shafts and U-joints
front driveshaft-custom CV shaft
Old May 21, 2012 | 05:07 PM
bbrown626's Avatar
Hey, thats some big money stuff! I was hoping read about people breaking a muffler bracket, maybe a reflector, sun visor or a latch on the glovebox. You know, cheap stuff.
Old May 21, 2012 | 05:24 PM
bowerss2's Avatar
I broke the air dam off a few times. I just zip tie it back on. It does help with hood flutter.
Old May 21, 2012 | 05:26 PM
remingtonJK's Avatar
The screw studs that hold the doors on. I threw the nuts with the broken screw parts away. Now I just run without them.
Old May 21, 2012 | 05:28 PM
Cosmos_Blue's Avatar
I don't mind taking my Jeep offroad, but I'm not mechanically inclined so if I broke something major I'd be screwed! Plus, it gets expensive fast.
When y'all broke something, how did you fix it? Spare parts? Limp back?
Raisinhead's Avatar
My wallet...
Old May 21, 2012 | 05:46 PM
JoabsJKS11's Avatar
what have i broken......hMMMM that is a long list...for a 9 month old Jeep.
**right axle shaft: $200, replaced with takeoffs craigslist
**clutch: $700, warranty covered it OEM Dealer part,
**steering gear box main shaft that holds the pitman arm: $300 craigslist
**clutch again, $500, replaced with a center force clutch kit
**clutch slavemaster: $200, warranty
**passenger seatbelt units front and rear: $700, warranty
**cracked engine block, warranty, who knows what that would have cost. the dealer thought i was leaking engine oil from the rear main seal and turned out to be a crack they say is a stress fracture maybe caused by the factory when the oil pan was being tightened.
Old May 21, 2012 | 06:11 PM
Surf City Dan's Avatar
The fuse blew for my cigarette lighter... Very frustrating but I was able to fix it.
Old May 21, 2012 | 06:20 PM
lowe516's Avatar
The tabs that hold the center console tray up.
