What more do I need? Have 4 in suspension kit from Rough Country.
I just had a 4 in suspension kit from Rough Country installed and now I am wondering what more do I need. It is a 09 automatic 2door X-s.
This is what it came with:
Front: Lifted coil springs, track bar bracket, pitman arm, sway-bar links, brake line brackets & hardware.
Rear: Lifted coils springs, track bar drop bracket, coil correction plates, cam bolts, brake line relocation brackets & hardware.
Shocks: Features (4) Performance 2.2 series shocks.
I have been looking at threads about lower and upper control arms, front track bar, and other things like that. This is my first jeep and very new to this. It will be a DD and little trail riding as there are no trails in south Texas. But would like it to be prepared if the chance comes up to do some trails. I will be putting on some 295-65-18 Goodyear Wrangler DuraTrac when they get in.
The rear drive shaft fails first on 2dr due to the angles presented with a 4" lift and front lca's to help to get you back to stock castor, it'll be pretty flighty at highway speeds if you leave your stock arms on I'd say get adjustable arms
I used the control arm brackets and really like them. Make it drive a lot better. If you are going to use them, then don't cut out the factory slots the instructions call for on the control arm mounts.
If I were to get the bracket for stock control arms would I be able to put adjustable control arms and would it be worth it. Or just go adjustable control arms without bracket. Or just bracket and stock control arms.
Has anyone try Rough Country X-flex adjustable control arms. I am looking at getting new adjustable lower control arms and found these. I know the price is cheap and you pay what you get for but currently this is by budget. OR if anyone has a different opinion please share with me.
