Stock Fog light wire colors
Old May 22, 2012 | 02:14 PM
HillCountry_Cowboy's Avatar
Default Stock Fog light wire colors
Have a question for folks who have the stock fog lights and have dug into their wiring. I just hung a 2011 bumper with fogs on my 2008. There is a wire loom routing behind the bumper area with only 2 wires in it- 1 red and 1 green w/yellow stripe. Is it safe to assume these are where the fogs can tap into the harness?
Old May 22, 2012 | 02:20 PM
Hotspur's Avatar
Yes, those are the colors on my 2010 fogs. Do you have a foglight switch on your light control column?
Old May 22, 2012 | 02:33 PM
ronjenx's Avatar
According to the 2008 wiring diagram, the right fog light wire is white with orange stripe, and the left fog light wire is white with yellow stripe.
Those are the colors from the light all the way back to the TIPM.
Old May 22, 2012 | 02:37 PM
Thanks. I don't have the switch. Eventually I may add a switch. In the meantime I wanted to tap the fogs into the harness and use my Procal to set the fogs to behave as DRLs. If it works they will be on anytime the engine is running and the parking brake is off.
If that turns out not to work I'll go old school and run a wire all the way to the dash and install a toggle switch.
