Aev tire carrier install on stock bumper
Old May 22, 2012 | 07:06 PM
rtguy1's Avatar
Default Aev tire carrier install on stock bumper
Just ordered the AEV TIRE CARRIER from Dave @Northridge4x4!! It will be here on Friday I'm going to install it with the CHMSL kit on a stock bumper. Any tips on install? I will be putting on my lift, wheels, and 35's too. I will post up as soon as its done.
Old May 23, 2012 | 08:02 AM
TNGatorBrad's Avatar
I've been thinking about the AEV... I can't wait to see yours installed.
Old May 23, 2012 | 08:16 AM
rdubb1031's Avatar
I installed mine all on my own.. It would have went a bit faster with an extra hand, but still pretty easy. I used a dremel and a hole bit, which helped a ton. Just make sure you get your adjustment right, when leaning it in to the vehicle it will make for smooth operation. Other than that..enjoy..
ID:	320465Click image for larger version
Old May 23, 2012 | 09:55 AM
JpAdct's Avatar
What does this kit run? I always thought you had to buy the whole bumper/tire carrier assembly, this is great news!
Old May 23, 2012 | 10:20 AM
TCJK11's Avatar
$859. I'd say just save up for the whole bumper.
AEV JK Rear Tire Carrier (10305020AA)
Or try out Hanson's
http://northridge4x4.com/shop/hanson...carrier-jkt2-p
Old May 23, 2012 | 10:43 AM
JpAdct's Avatar
Thanks, but why save up for the whole kit? I. This not a solid set up when ran with stock rear bumper?
Old May 23, 2012 | 10:55 AM
DeVoTee's Avatar
Very SOLID... I have had mine installed for about 4 months.
Old May 23, 2012 | 11:47 AM
rtguy1's Avatar
the tire carrier is unchanged regardless of the bumper used...it mounts the same way..to the frame....the aev bumper comes with a hole already to accept the passing of the spindle to the frame. it will not be any different...but the aev bumper is nice if you are looking for a new bumper as well. you can buy the bumper seperate later on as well if you want it
Old May 23, 2012 | 01:03 PM
antonioso's Avatar
Can the AEV tire carrier be installed on more or less any after market bumper also? givien that the bumper offers enough room to mount it to?
Old May 23, 2012 | 01:13 PM
rdubb1031's Avatar
Or try out Hanson's
Hanson JK Tailgate Mount Tire Carrier (JKT2-P)
For once I'd say, don't buy from N4x4. I got mine local for $699 plus tax. much cheaper. (for the record I called N4x4 first, just shipping is expensive)
Not always, it depends if the AEV mount gets in the way of the bumper mount. Also you'll have to drill through the bumper for the spindle..
