Trailer hub jeep wheel question?
Have a trailer hub 5x5 trying to mount '08 jeep wheel on, hub bottoms out on wheel before it is flush, jeep wheel has lip that hub hits. what do i do get a adapter, how did any of you fix problem?
Also I have the same tires on my trailer that is on my jku - so that I don't have to carry a spare tire for my trailer... 2" spacer is the minimum thickness to make the wheel fit... I tried 1.5 and it wasn't enough, the 2" will give and 1/4-1/8" space between the hub bearing dust cap and the back of the jk wheel center cap flange on the wheel... Cost was $60 for the spacers
I used 1.5" spacers on the hubs, so I planned my axle length accordingly, found that certain dust caps for the hubs were better shaped to use in conjunction with the center caps (more conical, rather than flat-topped). Then, shaved the inside "teeth" from the Jeep wheel center cap by first using a pair of side cutters, then, running it on my belt sander to flatten/true-up the back side.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=321688"/>
Trimming the wheel center cap is a great ideal! I thought about doing that when I tried the 1.5 spacers... I couldn't find any smaller hub dust caps except the tradition conical top that is sold everywhere... Do you have a picture? The other thing I considered is that I wanted to be able to easily use my jk's spare on the trailer if needed so I just went with the thicker. The edge of my tire protrudes slightly outside the fender lip...but manageable.
Thanks for all the info fellas, ordered the adapters I think it will work now.
