tf leveling question
Old May 25, 2012 | 01:27 PM
xizang2010's Avatar
Default tf leveling question
I'm starting the install of my tf leveling kit. one question I have, how high do I need to raise it up? for example, on a stock rubicon, any know how high off the ground the tires need to be before I put the jack stands under it?
thanks
Old May 25, 2012 | 01:30 PM
Kaisoboy's Avatar
It needs to be at least 2 to 2.5 feet up for good clearance.
I did mine with a buddy last Monday. Had it done within 1.5 hrs.
Here is my thread with some suggestions:
https://www.jk-forum.com/forums/jk-s...talled-232958/
Very easy to do. If you need anything else just ask and I will try to help you out.
Old May 25, 2012 | 01:47 PM
xizang2010's Avatar
thanks for the info. where did you jack it? differential? I have hilift hack stands, just not sure I can get it up that high with the jack I have.
Old May 25, 2012 | 01:54 PM
Kaisoboy's Avatar
Is it a floor jack? If so what size? 2.5, 3.0 tonne.
If it is a 2.5 tonne floor jack you may need to use some blocks to get it higher, jack it up at the jack points per the manual and put the stands on the frame. once it is jacked up and supported jack it up at the banjo housing before you unbolt anything making sure not to bend the gear plate. This will alow you to lift and lower the axle.
We had four jack stands so the whole vehicle was jacked up and resting on the stands.
Old May 25, 2012 | 02:00 PM
Kaisoboy's Avatar
I wish I took pics of the install but we were going so fast there was no time...
Old May 26, 2012 | 03:16 PM
Kaisoboy's Avatar
So how did the instal go?
