2.5" TeraFlex BB with 3/4" Spacers
Hello,
I've seen other members using this combo to help level their jeeps / eliminate the slight rake. My question is how do you install the kits together. Which ones go first. The TF before the 3/4" coil spacer or vise versa
..Thanks...
*** The 1st pic shows the TF being installed first and then the factory coil rubber isolator. If I was to install the 3/4" spacers do I install it after the TF and use the 3/4" to replace the factory coil isolator or do I install all three together in this order (TF, 3/4, factory isolator)???
3/4" spacers
..Thanks...*** The 1st pic shows the TF being installed first and then the factory coil rubber isolator. If I was to install the 3/4" spacers do I install it after the TF and use the 3/4" to replace the factory coil isolator or do I install all three together in this order (TF, 3/4, factory isolator)???
3/4" spacers
