'07/Aftermarket Valve Stems
Old Dec 22, 2007 | 06:25 PM
TORN's Avatar
Default '07/Aftermarket Valve Stems
What kind of valve stems are you all using? metal or rubber, and why?
Old Dec 22, 2007 | 10:05 PM
macfamm's Avatar
Default High-Pressure
I use standard high pressure valves. I used to use steel inner mounts, but they tend to leak more than a pull-in rubber stem. Also, they don't flex at all, so if you catch them on something they can simply break-off.
The high-pressure valves aren't the best looking valves if you're looking for bling, but their large base (part that's inside the air chamber) makes them very hard to pull out. That's why they're high-pressure rated.
Here's what they look like.
http://www.myerstiresupply.com/pls/m...rt_id=kflf6443
Old Dec 23, 2007 | 02:03 AM
TORN's Avatar
Those look like they would work well. Thank you
