Cooltech Cb Mount?
Old Dec 22, 2007 | 10:12 PM
aggiejeep's Avatar
Default Cooltech Cb Mount?
hey i was wondering if u can take the switch panal that cooltech sells with out switchs and make it into a cb mount? does anyone think this will work? help please before i order it and eff it up
Old Dec 22, 2007 | 10:30 PM
CJK's Avatar
CJK
If you're talking about the empty panel at the bottom of the "stack" just in front of the shifter it won't work - that's not an empty hole they just covered up. Lots of guts behind there.
Old Dec 23, 2007 | 05:58 AM
RubiconOrdie's Avatar
Default Correct
Yup, there is stuff behind that thing. I had plans like that too until I pulled it off.
Old Dec 23, 2007 | 07:40 PM
aggiejeep's Avatar
so no way to make it work??
i dont mind relocating some wires and stuff
Old Dec 23, 2007 | 08:12 PM
Default Nope
It isn't just wires, it's ducting or something...you're physically blocked. You can remove that entire piece by using a plastic pry or a screw driver...it just snaps into place. I say plastic pry but if you don't have one be careful since it's easy to scratch the plastic.
