Toyo Open Country A/T 275/70R18 fit without lift or spacers?
Old Dec 23, 2007 | 09:58 PM
TyWebb's Avatar
Default Toyo Open Country A/T 275/70R18 fit without lift or spacers?
Just as the title says. I was looking to get the Toyo Open Country A/T 275/70R18. Does anyone know if these will fit on the stock sahara rims OK without rubbing? The overall Tire diameter is 33.2 inches.
Is anyone running this tire? What do you guys think? Will they fit on without spacers or lift without rubbing?
Thanks!
Old Dec 24, 2007 | 05:38 AM
TEEJ's Avatar
Talking
The widest OEM width is 265, you are talking about another 10 mm, of which, only 5 mm will be inboard more...., so, what you are asking is if a ~ 0.2" will rub?
I'm guessing, no, maybe a 285 sometimes.
You could get them, and just get a set of spacers if you find that they do...but a 5 mm difference would seem to be pretty safe.
Old Dec 24, 2007 | 09:50 PM
TyWebb's Avatar
I guess youre right TEEJ, not much of a difference in size.
Bump for pics of anyone running this size?
