Soft top Question- What am i doing wrong?
So... I have the soft top on my JKU. Its sunny out and I just want to use the sunrider portion of it. I unlatch the front and fold the top back. But when I go down the road, the middle dips down on the passengers in the rear seats and creates a shallow V in the middle. It also buffets quite a bit. Is it supposed to be this shitty? Or am I doing something wrong. it seems like a relatively simple process.
There should be weak points in the plastic you had to pop out from the door jambs once you find those the top folds back like a accordian it helps me to have someone on the other side...on my 2d my sunrider makes a z shape when folded back...hope that helps
Its not being folded correctly. make sure its folded as shown in the first pic, not in the second pic
Edit: Also heres a video. hope it helps (watch at 29 seconds in to see how to fold top correctly)
http://www.youtube.com/watch?v=tuByrJfuSOQ&feature=player_embedded#t=28s
Thanks again.
Your welcome. Dont worry about the plastic clips, they changed the soft top design in 2010
The new tops have a tension spring instead
