rear trackbar relocation with teraflex older budget boost help
Hi I m installing a teraflex budget boost 2.5 spring lift with shock adaptors and I have everything done on it besides the rear trackbar relocation mount that was proivided in the kit. I am totally stumped on how to put this bracket on so I can bolt the trackbar in because the holes do not line up. Also, I am a bit confused on where to drill and how to position this bracket, any help would be greatly appreciated.
I have the 2.5 lift with the shocks and I ran into a similar problem with the rear trackbar bracket. I called Terafelx and had the issue worked out in a couple of minutes. If you have the big trackbar bracket what I did was attach it to the rear driver side lower control arm and the trackbar, then work on the u bolt and trackbar bbracket bolt. Hope this helps.
JD
JD
You have the drop bracket for frame side? If yes, I had to 'walk' the hole with the drill for mine to line up. I think there is a thread on here where someone has the correct offset. When I did mine, I didn't have time to search for it, so I used the Neanderthal method. Have had zero problems like that.
