Teraflex 2.5" spring lift reverse rake
Old Jun 24, 2012 | 07:35 AM
Mastiff's Avatar
Default Teraflex 2.5" spring lift reverse rake
Anyone else have this? It's not major, but I can see my Jeep in the carport from my living room, so I see it all the time. I have the factory plastic bumper up front and an LoD stubby with swing out tire carrier, full sized spare and hi-lift in back... so maybe it's just sagging from the weight? I may get a steel bumper up front, but I really have no plans for a winch any time soon, so I don't think I'll ever level it from the weight.
I wonder if I should try one of the adjustable leveling kits? I haven't really researched them yet, but I assume you'll get a minimum 1" or something from it? Any other ideas?
Old Jun 30, 2012 | 06:33 PM
PUSHNF8's Avatar
Mine is doing the same thing. Also 2.5" teraflex. Im going to add a 1" spacer to rear to level it out
Old Jun 30, 2012 | 07:05 PM
bOLsAK=3's Avatar
Those TF 1" spacers are an easy and affordable way of getting it to the level you desire. I totally agree with the post above and also recommend it.
Old Jun 30, 2012 | 07:29 PM
HighTide's Avatar
X3 on the spacer... going to add one to the front of mine to level it up due to bumper and winch.
Old Jun 30, 2012 | 08:09 PM
Mastiff's Avatar
How painful to install the spacer? I've done lots of work on leaf sprung vehicles but have never messed with a coil/arm suspension. Does the track bar have to be disconnected?
Old Jun 30, 2012 | 08:33 PM
jesse0376's Avatar
Track bar takes seconds to disconnect its very easy to install spacers
Old Jun 30, 2012 | 09:00 PM
Willis19's Avatar
I have the same kit but mine was leaning to the right and i had no idea why so I called Tera flex and they sent me 1" spacers to put in and it worked so I can't complain anymore
Old Jun 30, 2012 | 09:20 PM
BubbaJK2012's Avatar
I have an adjustable system and still added a 1 inch to rear!!!
Old Jul 1, 2012 | 06:49 AM
Ryan0260's Avatar
I can tell you that adding a bumper and winch up front will drop your front down and level it. If you plan on doing this, I would hold off on the spacers
Old Jul 1, 2012 | 07:08 AM
Mastiff's Avatar
Any issue getting the track bar lined up again after doing the work? Or does it just kind of work out as long as the jacks don't move?
