axle swap ?s and others...please help
Okay got a used '07 "X" 2-door with 2k miles for $16k yesterday and now I am starting to follow through with my plans. Plans are to build d44s to run 36s-37s and installing an atlas 5.0.
I am ordering a front Rubi d44 and wondering a few things...
1. How do I get the lockers to work? I am told just to rig a simple toggle switch, but I need more info than that.
2. I have a rear d44, but its just 30 spline...can the 32 spline shafts fit into this housing? What do I need to change out as far as the carrier, etc? If I can use my stock d44 I'll regear it and run a detroit locker.
3. Are front alloy shafts out yet?
[QUOTE=ZachMan;274670]Okay got a used '07 "X" 2-door with 2k miles for $16k yesterday and now I am starting to follow through with my plans. Plans [QUOTE]
what? i just payed $21K for mine (new) 6 mounths ago.... please dont tell me that these jk's loose vaule that fast... i mean look at the tj's cant find one under $12
(that's the reason y got got my JK (cheaper loan) )
what? i just payed $21K for mine (new) 6 mounths ago.... please dont tell me that these jk's loose vaule that fast... i mean look at the tj's cant find one under $12 Last edited by FLyellowjk; Dec 25, 2007 at 02:12 PM.
2. I'm not sure about using the 32 spline shafts, but I think you could if you also swapped out the carrier.
3. Alloy shafts should be available from Superior. Good luck.
[QUOTE=FLyellowjk;274730][QUOTE=ZachMan;274670]Okay got a used '07 "X" 2-door with 2k miles for $16k yesterday and now I am starting to follow through with my plans. Plans
Well as far as I know it has zero options besides A/C. Single cd, manual tranny, soft top, etc...
what? i just payed $21K for mine (new) 6 mounths ago.... please dont tell me that these jk's loose vaule that fast... i mean look at the tj's cant find one under $12 Well as far as I know it has zero options besides A/C. Single cd, manual tranny, soft top, etc...
[QUOTE=ZachMan;274902][QUOTE=FLyellowjk;274730]
same here... just kkb it said the same thing... i guess the 2 doors dont hold value
well good luck on your build!
