New JKUR Coming Soon... Need some guidance with initial mods please!
Old Jun 24, 2012 | 07:52 PM
AlanC's Avatar
Default New JKUR Coming Soon... Need some guidance with initial mods please!
Hello all,
I've got a new 2012 JKUR on order and it should be arriving at my dealer in the next couple of weeks.
I'd like to make some initial modifications after it arrives, and I was hoping to get some guidance here so I can get some parts ordered. Here are a few things I'm considering:
1. Tires
I'd leaning toward a set of Goodyear Duratracs in size 315/70-17.
I like these because I live in Colorado and I see quite a bit of snow in the Winter months and these seem like they will perform in the wet/snow better while still giving me respectable off-road performance.
I don't do a lot of hard core wheeling, mostly just exploring the local fire roads in the nearby mountains. I need a good off-road tire, but I don't think I need a full on MT for what I do.
2. Wheels
It looks like a lot of folks are running the above tires on stock wheels, even though from the specs it seems like they want at least an 8.5" wide wheel. How much of a concern should this be?
From my research, it looks like I could run this size tire on the stock Rubi MOAB wheels if I used a 1.5" spacer.
I like the ARE Pintler wheels a lot. Do these have the correct amount of backspacing to run this size tire without spacers?
3. Lift Kit / Suspension
I was originally leaning towards a lift kit in the 3-3.5" range from Rock Krawler or Teraflex.
From what I gather, going over a 2.5" lift will require me to swap out driveshafts, so now I'm thinking about starting out with a 2.5" spring lift and possibly upgrading to a higher lift at a later time if I decide I need to.
Would this be enough lift to run these tires for some light duty wheeling?
4. Gearing
I ordered my Jeep with 4.10 gears with the 5-speed automatic.
Is this ratio good with the 34.4 diameter of these Duratracs?
Thanks,
Alan
Old Jun 24, 2012 | 08:09 PM
2011Sahara's Avatar
Alan, congrats on the jeep. With 4.10's and the new motor you should be just fine. I'm running duratrac 275 65 r18 on my Sahara now (about a 32" tire) getting the 2 1/2" OME coil lift done tomorrow. I'm hoping they don't look too small and will upgrade to a bigger tire prob 33 when these wear out. I think you will be just fine with Your lift and tire combo considering your intended use. Honestly, I've never been let down with it in stock form, I just want more clearance now that I've installed an arb bumper, stock suspension a little too soft for me. While I can't speak about the width of your tire and rims, you will love the duratrac tire. Ive owned two sets in 2 different vehicles and absolutely happy with them.
Good luck
Old Jun 24, 2012 | 08:18 PM
Zombie Hunter's Avatar
I really like my Goodyear Duratracs 315/70-17 on my AEV Pintlers. A great combo, don't rub and don't stick out as far as other wheels.
A 2012 with 4.10 gears and 5 speed auto should do very well with above tire size. Suggest AEV ProCal to adjust speedo so gears will shift close to stock.
2"-2.5" lift is also a good height. Not too much to require alot of other mods.
Sounds like you thought this out.
