285/70/17 W/ Procomp 7005s
Anyone know if I can go with 285/70/17 BFG KM2's and Procomp 7005's without getting a lift? Eventually will be getting a lift but its just not in the budget to get both right now. And I've heard you can't get a lift and keep the stock rims, plus it would look terrible... Hahahahaa
I've seen blokes run 35" tyres with no lift but there was no room for flex.
What you're about to put on is just shy of a 33" tyre.
I'm about to put the exact same size maxxis bighorn on my jku rubi and have been told it may rub the air dam at the front and i'll either trim it to fit or replace it with a bash plate.
Also i was worried about the pinch seams in the rear and rock sliders but it. Shouldn't be a problem.
However i have a 2" spring lift.
