Rough country 2.5" lift and 1.25 body lift
Old Jun 27, 2012 | 04:57 AM
N_oikion23's Avatar
Default Rough country 2.5" lift and 1.25 body lift
If i get that do i need to replace the driveshafts if so which ones and is that kit everything i need?? Thanks for the help in advanced im looking to buy this week
Old Jun 27, 2012 | 05:19 AM
robinson86's Avatar
If you check with RC, the install instructions, will tell you the driveshafts are not necessary. You can download the install instructions from their website.
Old Jun 27, 2012 | 05:27 AM
N_oikion23's Avatar
Ok thanks alot
Old Jun 27, 2012 | 05:35 AM
ricky-2012jku's Avatar
With a 2.5 you don't need me drive shaft. If you have a '12 depending on how much lift you actually get out the coils. You either will need. The exhaust spacer or new front drive shaft.
Old Jun 27, 2012 | 05:43 AM
N_oikion23's Avatar
I have a 12 stick 2 dr
Old Jun 27, 2012 | 06:38 AM
N_oikion23's Avatar
Morning bump
Old Jun 27, 2012 | 04:31 PM
N_oikion23's Avatar
Bump again
Old Jun 28, 2012 | 03:38 AM
N_oikion23's Avatar
Next day bump
Old Jun 28, 2012 | 04:07 AM
Ol' Bob's Avatar
The body lift is zero impact in the drive line.
The lift with shocks and springs is all I used and no issues. I have a 2010 2 door. I know the new models have the exhaust issue. That would be your only possible snag.
It's an easy install. You're gonna have a blast playing with the Jeep. No worries, just jump in.
Old Jun 28, 2012 | 04:22 AM
N_oikion23's Avatar
Wat size lift do u have? Are those stock rims and tires? Your jeep looks sick
