Jeep Dealer says"Axle differential seepage is normal..."
Old Dec 31, 2007 | 01:45 PM
Angry Jeep Dealer says"Axle differential seepage is normal..."
OK, after I lifted my JK. I noticed that both front and rear pumpkins are greasy from fluid leak. I took it into the dealer today and just got it back.
On the explanation form it said" Axle seepage is normal, only dripping fluids are covered under warranty" WTF?!
The other crazy thing is that I bought it in for them to fix the axle pinon SQUEAK TSB. And they ended up replacing front brake pads and calipers under warranty. I have 8K miles and I guess that was a bonus.
After talking to the GM I now have to bring it in again for the TSB and the seepage issue repair.
Since when is fluid seepage "Normal"?
Old Dec 31, 2007 | 01:48 PM
TEEJ's Avatar
Talking
Sometimes, when you get a lot older....
Old Dec 31, 2007 | 03:48 PM
150's Avatar
150
Fallen Hero
Good one!
Old Dec 31, 2007 | 04:08 PM
fullthrottle's Avatar
i had a dealer tell me the same thing acouple years back,said it was just sweating and it was normal and not covered
Old Dec 31, 2007 | 04:17 PM
SteelMastiff's Avatar
One of the dumber things I've heard in life...
Old Dec 31, 2007 | 05:19 PM
cjsdad's Avatar
I had my seepage taken care of. My wife didn't like the marks I was leaving.
Old Dec 31, 2007 | 05:34 PM
Robar's Avatar
I guess in one aspect it is normal, because a lot of JK have it. I had some, so I took a wrench and tightened the bolt about 1/4 to 1/2 turn, cleaned them up, and no more seepage.
Old Dec 31, 2007 | 05:44 PM
bly109's Avatar
I know ours did, but it was because the RTV bead didnt make it all the way around the cover.....sucked water right in.
Old Jan 1, 2008 | 09:58 AM
rickl's Avatar
Default very poor factory silicone seal on diff covers
put warn diff gaurds on front+rear 44's in my rubicon,both leaked,pulled both covers to reseal should have took pictures of terrible job of applying sealant to cover,when ready to change diff oil highly recomend all JK owners reseal covers,make sure you use a grey silicone sealant(readily avail at most parts stores) and dealership will never know you resealed(except NOT leaking)also in my experience as a heavy truck mechanic highly recomend let silicone cure 2-3 hours prior to refilling diff+driving
Old Jan 1, 2008 | 11:01 AM
tgrt's Avatar
Former Vendor
Thanks man. Not an image I needed...
