LoD rear bumper reviews needed
Hi there, I'm looking for any user experiences relating to the "LoD Jeep JK Shorty Signature Series Rear Bumper w/ Generation 3 Tire Carrier", preferably on a 2011 or 2012 JKU.
Does anyone have any direct experience with this bumper, from installation, usage, maintenance, fit and finish to product durability?
Thanks - Rob
Thanks - Rob
Thanks - Rob
Thanks - Rob
Not sure what else you want to know, but I'm happy to answer any questions you have. PM me.
Few pics of mine here: LOD signature shorty installed
I installed mine by myself and a floor jack. It was pretty straight forward once you install the first time you'll mark a hole on each side of the frame and drill it. Then reinstall the bumper and install the additional bolts. It's built really well my only complaint is the the rear fog lights. If or when one goes out I'll need to drop the bumper to replace the bulb or light.
I have that bumper. I had a little bit of help with the install. The bumper is sturdy, carrier is strong. One complaint I have is the locking pin that holds the tailgate open at 90 degrees does not have a grease fitting. The pin sticks inside the sleeve and does not move easily. I've sprayed it with lubricants a few times but it doesn't last long. It could be a result of salty winter roads corroding the insides.
Other than that, I'm quite pleased with it. Looks good, holds the tire solidly, latches tight with no wiggles or rattles... It's taken a few hits on rocks with no movement and minimal scratching of the powdercoat. I'd buy it again.
Very very happy with my LoD rear Stubby (I have a matching front as well) - install was easy - just make sure you follow their directions
and get the alignment correct BEFORE you drill into the frame.
Came out real nice. No rattles, fit is amazing. Function is 100%!! I even got a mount point for my hi-lift.
the 3rd brake light is way to high - I got the matching kit but the reality of it with
37s it is just to high and makes no sense - I hacked it off and now it shines out
one of the spare tire/wheel holes.
I used their kit and cut it down so it shines out one of the holes.
