OME LT Kit 2012 JKU Driveshaft
Old Aug 1, 2012 | 05:59 AM
marmot74's Avatar
Default OME LT Kit 2012 JKU Driveshaft
I am putting a OME LT Kit (HD Springs) on my 2012 JKU and I plan to replace the Front Driveshaft with a Coast at the same time.
Do I still need to do the Teraflex spacers or the AFE y-Pipe?
Thanks
Old Aug 1, 2012 | 06:02 AM
walker111's Avatar
Yes. IMO, and in my experience, the TF spacers are a waste of money.
Old Aug 1, 2012 | 06:49 AM
HornetJK's Avatar
I have the same OME LT HD kit and the drive shaft just touches the exaust when the jeep is fully off camber/ flexed. You should be more than fine with the drive shaft. This is assuming you are going with the 2-3" kit and not the 4". To be sure give Dave at Northridge 4x4 a call.
Old Aug 1, 2012 | 06:50 AM
wayoflife's Avatar
JK-Forum Founder
Thanks
no. you will not need to do the spacers or y-pipe if you install a new drive shaft.
Old Aug 1, 2012 | 06:51 AM
marmot74's Avatar
Thanks guys!
Good to know I don't have to mess with the exhaust.
Old Aug 2, 2012 | 07:44 PM
marmot74's Avatar
One more question on this lift. It comes with a rear trackbar so should I get a rear trackbar enforcement at the same time? Which one would go well with this kit?
Thanks
