Lift question
Old Aug 1, 2012 | 07:53 PM
Willis19's Avatar
Default Lift question
Ok I have the 2.5 in teraflex suspension lift with 35s and I have adjustable track bar and quick disconnects.
Now my question is my jeep leans to the right about 1" Do basically it sags to the right 1" lower then the left so I called Tera flex and they sent me spacers and I put them in but I feel like its just rigged up and I don't like that idea...
So does anyone know a way of fixing this or does someone out there have the same problem and found a solution ???
Any help would be great thanks!!
Old Aug 1, 2012 | 09:08 PM
1978cj7jk2012's Avatar
Chances are it is your stock springs causing this problem and has nothing to do with Teraflex. Most jeeps come with a spring that is 1/2 coil longer on the right than the left to make up for the weight of the gas tank. Look at your tags and that will tell you if they are the same or if one is taller. The last 2 digits are how you tell. Take mine for example. 2012 stock sport springs, last 2 numbers were both 14, so my jeep leaned to the right like yours. I bought and installed 2012 rubi springs, 17 on left 18 on right, now my jeep is level and lifted 2 inches..
Old Aug 2, 2012 | 06:28 AM
Willis19's Avatar
I have Tera flex 2.5 springs with a 1" spacer on the right side
Old Aug 2, 2012 | 06:31 AM
Willis19's Avatar
I dont have stock springs I have tera flexs 2.5 springs then just in the right side I have 1" spacer to correct the lean... But my coils look more compressed on the righ side
Old Aug 2, 2012 | 06:50 AM
davidslavin's Avatar
Just recently I found out that my Pro Comp 2.5" was set to the left 1" on the shocks and suspension. I simply took it to a tech. and had it straightened by him. Also, I had my alignment fixed because the shocks and suspensions set to the left 1" was causing my JK to lean to the left and drive poorly. I'm not sure if this helps, but maybe it does?
Old Aug 2, 2012 | 12:00 PM
riche6476's Avatar
Is anyone running a Zone lift?? I currently have a 3" kit and i HATE it!!! Im not sure if its the lift or the install but it is mushy as can be!! I can understand that I am a big fat dude but i am rubbing on my rocksliders when I take corners on trails. anyone else having this issue???
Old Aug 2, 2012 | 12:14 PM
ricky-2012jku's Avatar
What shocks are you running.
Old Aug 2, 2012 | 12:18 PM
riche6476's Avatar
i am running stock rubicon shocks in the front and skyjacker shocks in the rear.
Old Aug 5, 2012 | 08:12 AM
Willis19's Avatar
So does anyone know how to fix this problem ?!
Old Aug 5, 2012 | 12:49 PM
SIDsjeep's Avatar
Veteran: Coast Guard
ever think about using air bags? it may help, ive been thinking of doing this after putting my gobi rack on and the whole leaning to the right because of a full gas tank is rather annoying.
