Right Rear Sags
I have an 08 2 door with 60K miles. A 5.5" BDS suspension and LOD front and rear bumpers. In the past 3 months, my right rear has started to sag. Can someone please provide some advice as to why this would happen only on the right rear and what the fix would be? I have compared the level with and without a full tank of gas as the tank is on that side and there is no difference.
I have searched and found nothing. What I do know is it was level before with the LOD bumpers and now it isn't.
Thanks!
Thanks!
a passenger side lean is totally normal. in fact, i call it the JK lean. you can easily address this by installing a set of adjustable rear sway bar links and setting the passenger side ones longer.
Thanks!
Thanks!
Inspect the rear springs, and if they are seated, you could try switching the two rear springs to see if it makes a difference.
Mine leans to the right a little. I got a .5" spacer for the front and rear on the passenger side and just haven't installed them yet. I may not actually as I'm used to it. You don't even really notice too much after a while
